do i need to install the spc toe bolts?
Old Jan 21, 2010 | 02:38 AM
chipstackn's Avatar
hi i recently installed the rear camber arms on my 05 coupe and took it in for a allingment i told the guy that he needed to dremel out the hole a little so he could install the toe bolts he said no prob, when i went to pic my car up he said i didnt need the spc toe bolts that the factory ones were good enough he said that my specs were very good close to factory and i didnt need them can anyone shed some light on this thanks allot btw im dropped on g35 tein s techs
Old Jan 27, 2010 | 12:53 PM
chipstackn's Avatar
anyone?
Old Jan 27, 2010 | 12:57 PM
G35Papa's Avatar
If the shop was able to get you back into spec you don't need to install them.
Old Jan 27, 2010 | 01:05 PM
Dubi2087's Avatar
The only time you will need them is if you can not bring your toe back to spec. Since the shop was able to bring your toe back to spec than I wouldn't worry about it. BTW did you get a print out of your before and and after specs.
Old Jan 27, 2010 | 01:10 PM
The Stimulation's Avatar
Did he say it was within factory spec or close to being within factory spec? If it's close to..i'd be on the safe side and have them install it and get it within factory spec. If it's within spec, no need to install.
Old Jan 29, 2010 | 07:43 PM
chipstackn's Avatar
yes i got a printout my rear camber is (left)(before -2.1) (after -1.7)
(right) (before -2.0)(after 0.9) and my toe is (left) (before 13/32") (after 3/32")
(right)(before 3/32")(after 1/32") (total before =1/2")(after total=1/8") im not to sure about the toe specs!but he said they were within spec any input would be much apreciated thanks in advance!
Old Jan 29, 2010 | 07:44 PM
chipstackn's Avatar
linedr89
Aug 17, 2015 05:11 PM
EPG35
Aug 16, 2015 04:52 PM
CrazyLogic219
Aug 13, 2015 06:40 PM
jimNC
Jul 25, 2015 05:47 AM
