Suspension
Old Feb 10, 2010 | 08:54 PM
tom125's Avatar
Suspension
Hey I want to get lowering springs for my car. I have a 2005 g35 coupe. whats the lowest I can lower it with springs and are springs good and what kind of springs do I get, and where Thanks
Old Feb 10, 2010 | 08:57 PM
O HELLA OEM's Avatar
SEARCH is your best friend.
Old Feb 10, 2010 | 09:17 PM
tom125's Avatar
suspension
well what is the lowest i can lower my car with springs without messing anything up??
Old Feb 10, 2010 | 09:18 PM
i dont think any springs go lower then 2".
if your planning on getting a drop you should
definetly purchase a rear camber kit and a front camber kit
so you dont have uneven tread wear.
Old Feb 10, 2010 | 10:46 PM
tom125's Avatar
ok how much does these camber kits cost?
Old Feb 10, 2010 | 10:47 PM
search
Old Feb 10, 2010 | 10:49 PM
SGrice7's Avatar
Eibach Pro Kit is good, Tein S-tech/H-tech Springs, Tanabe..it's really about what you want. I went with Tein 350z H-techs. If you've got the cash get coilovers, but if you're just looking for lowering, springs will do.
If you're looking for as low as drop as possible I would definitely get a front and rear camber kit so you're tires don't wear. The breaking point for needing camber kits is around 1". My H-tech's gave me about 1" drop and an alignment was able to get camber settings back to normal w/out need for camber kits. I've heard its a maybe for (350z) H-techs so I got lucky. If you don't make the cut, usually a rear camber kit will do and you can get one from $75-$175.
As for purchasing, look in the Marketplace forum, good discounts for members in there.
Do some searching, theres a lot of info available in the forums. Check this out https://g35driver.com/forums/brakes-...w-updates.html
Old Feb 10, 2010 | 10:52 PM
Og_Dave's Avatar
lol search is just a few clicks away
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
