Question about wheel studs
Alright guys
So recently my studs broke in my passenger rear and one is stripped in the front driver side. I've decided to replace all of them and I was wondering is it possible to replace them yourself? I'm going to attempt the rear, but I heard the fronts are difficult. Let me know I WANNA GO TO WEKFEST!!!!
Thanks
Thanks
front and rear are the same. simply take off the wheel, take off rotors and calipers with the brake pads. turn the hub so you have enough room to hammer them out. spray wd40 and let it sit for like 10 mins. take a hammer, then slam it out of the rear, just make sure you have room in the back for the new one to fit back in. stick in the new one, and attatched the lug nut to the other side of the hub. (best to use a open ended nut) stick it on, and use an air gun to tighten it. as the lugnut will tighten, it will pull the stud through.
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
