Camber adjustment question....
Old Feb 26, 2010 | 11:00 PM
xXHotelCrazyXx's Avatar
Since i have some negative camber and want to correct for it a bit, i just ordered Ichiba rear camber kit. Here is the gap on my car
What I am wanting to do is put a little more positive camber back in to to close the gap between the sidewall of the tire and the fender well. Will these camber arms allow me to adjust for that much gap? Also is it necessary to install the toe bolts that come with the kit?
Old Feb 27, 2010 | 12:00 AM
eurodre's Avatar
you can put more positive camber just don't get cusco those are mainly for neg camber
i believe SPC is the most positive adjustment
as for the toe bolt, you have to remember toe is what kills your tire faster so get the toe bolt installed so you can adjust toe to 0 and save them tires
Old Feb 27, 2010 | 12:11 AM
Well the ichiba is on the way, you think i should be able to close that gap between the sidewall and fender?
Old Feb 27, 2010 | 12:13 AM
eurodre's Avatar
depends on what camber you are at now
the general rule is 1 degree of camber gives u 5mm or space
Old Feb 28, 2010 | 12:06 AM
Sen's Avatar
Sen
Ichiba rears offer a decent amount of adjustment. It's the ichiba fronts which are almost worthless for positive adjustment.
Toe bolt is only necessary if your toe is too far out to be fixed.
Old Feb 28, 2010 | 04:29 AM
Whats wrong with the front camber kits from ichiba? not enough postive adjustment?
Old Feb 28, 2010 | 06:51 AM
biggz786786's Avatar
i would say get spl pro rear and spl fronts
spl pro rear give +/- 10 degrees and comes with toe bolts
while you are getting the rear, might as well get the fronts as a package deal, cause since you will be adjusting rear you might want to adjust your front to match that for even tire ware and better handling, but with that much camber, expect to ware out your tires pretty quick haha
i have to admit tho, your stance and overall style and stance is just pure sex on wheels
Old Feb 28, 2010 | 10:41 AM
Sen's Avatar
Sen
Exactly. The SPC kits come with these shims you install behind the hub assembly and brake caliper. The shim is wedge shaped so it creates a static positive 2 deg of adjustment. And if you don't need the full 2 deg, you can always scale it back with the adjustability of the A-Arm itself.
Old Feb 28, 2010 | 11:02 AM
Deezflip's Avatar
+1 the rear is fine. Just keep in mind whenever you change or adjust camber, it changes toe settings. With this said, you may be able to change a good amount of camber in the rear and be left with more camber adjustments to spare, but you might max out of the adjustability of the rear toe unless that toe bolt hole is elongated.
Old Feb 28, 2010 | 02:53 PM
SPC is the same is Eibach, same product different name from what i hear from several people? SPC sells its product under 3 different names?
Old Feb 28, 2010 | 03:03 PM
eurodre's Avatar
spl gives +/- 10 degrees ? that's WAY to high
Old Feb 28, 2010 | 03:11 PM
^yes it does, i have em
Old Feb 28, 2010 | 03:17 PM
eurodre's Avatar
well have you run -10 camber?
Old Feb 28, 2010 | 03:56 PM
BTW i also ordered the front camber kit as well, thanks all for the help! Trying to get my car on point with the new wheels and suspension!
Old Feb 28, 2010 | 03:57 PM
^ oh no, haha, im not a camber freak
http://splparts.com/main4/parts/Z33/...rmultilink.htm
i would recommend spl series parts for camber and toe
definitely spl pro rear camber arms and spl front camber combo is the best way to go, pay the little extra and get the quality you deserve
edit: first sentence was for eurodre
