Rear Camber Kit Didn't Work.. HELLLPPPP
Old Mar 6, 2010 | 09:47 AM
wreckshop56's Avatar
Originally Posted by VA 04 g35
you can just the toe bolt with any rear camber kit. the bolts are installed on a different arm than the camber arms
thanks
Old Mar 6, 2010 | 03:53 PM
gabe3d's Avatar
If you bought the Ichiba rear kit, it comes with toe bolts. Perhaps the shop that installed the kit didn't use the toe bolts correctly. Also, you will need to elongate the hole to get the maximum benefit of the toe bolt. Do you remember your alignment specs?
Old Mar 6, 2010 | 04:07 PM
TIAN's Avatar
Hold The Line
Originally Posted by Jackus
If your tires are feathered as if the tire was pointing inward or outward like your feet its definately toe.
+1
Great GIF
Old Mar 8, 2010 | 06:46 AM
I think I already have the toe bolt installed I wil take pictures today...
Should I go ahead and buy tires or wait till sals fix the problem then buy tires?
Old Mar 8, 2010 | 11:26 AM
GeezNuts's Avatar
i vote second option unless they are trashed already
Old Mar 8, 2010 | 12:27 PM
No1 picks up his phone.. Is it by appointment or can I just showup?
Old Mar 8, 2010 | 12:34 PM
Locksmith's Avatar
You shouldn't need to buy any toe bolts the ichiba camber kit should have the right bolts already for you to adjust the toe settings, just take it to any reputable shop and have them look at your camber kit.
Old Mar 8, 2010 | 01:52 PM
gabe3d's Avatar
In case you didn't know, the Toe Bolt isn't actually used for the Camber Arm, it actually connects the Midlink/Lower Control Arm to the Sub Frame.
Old Mar 9, 2010 | 10:55 AM
GeezNuts's Avatar
No gaurantee they'll be there, but you could try that too - if they aren't in the showroom - there are two bays to the right of the store on the back side where the actual shop is located - try sticking your head in there and asking for Sal or Oscar - tell them your issue - they'll help you out - might need to make an appointment, but super nice guys
Old Mar 9, 2010 | 12:54 PM
Deezflip's Avatar
+11111, it goes onto the spring bucket arm...basically the arm that holds the spring. Also, your shop has to be aware that they have to grind and elongate the hole to compensate the extra adjustments that the SPC bolts were made for.
Old Mar 9, 2010 | 04:12 PM
Heres the pics.. Sry about the quality and angle I had to take quick pics before i picked up my lil girl from daycare. Does it look like i have the aftermarket toe bolt installed because i dont want to buy one if i dont need it. Also can yall point it out 2 me.. As you can see the tires are messed up.
Old Mar 9, 2010 | 04:16 PM
Deezflip's Avatar
^that's not where the toe bolt should be. The SPC toe bolts should be somewhat cleaner/shiny depending on how long it's been on there. It's that bucket where it holds the springs... closer to the exhaust
Old Mar 9, 2010 | 04:18 PM
also i called sals and jtran or whatever both have to order the toe bolt thats y i want to know if i already have it installed. Now im going to discounttire and order me some tires.
Old Mar 9, 2010 | 04:19 PM
Deezflip's Avatar
*EDIT* my previous post
  #30
oh crap... lol ne1 got a picture so i can check
