g35 sedan + coupe H&R sports + coupe 19's = tire rub?
Old Mar 18, 2010 | 12:47 AM
stnwag0n's Avatar
I'm planning on lowering my 06 sedan with coupe H&R springs. I also want to use oem coupe 19s. Will I have tire rubbing issues? Should I just go with H&R sports for sedans, or will that also cause tire rub? I really dont want to have to roll my fenders.
Old Mar 18, 2010 | 09:26 AM
NjMatteSedan's Avatar
Depends on tire size. 225/40 front and 255/35 rear won't rub and will look good. That's what I have
Old Mar 18, 2010 | 09:36 AM
Matzo Ball's Avatar
that is what I will be running as well. On S-techs so it should be gtg.
Old Mar 18, 2010 | 10:56 AM
^ yea I'm on S techs as well, no problems. But I'm gonna put 10mm spacers front and rear. Front ones first cuz is more tucked than the back. Then ill get spacers for the back ones and roll rear fenders. I want the wheels to be flush
Old Mar 18, 2010 | 05:30 PM
stnwag0n's Avatar
coupe h&r springs are make the chassis considerably lower than s-techs dont they? or does the ride height not matter? i thought the offset was too low on the oem rays to use on a very low sedan without rolling fenders.
Old Mar 18, 2010 | 07:43 PM
ckkone's Avatar
255/35/19 with proper alignment and weight in the back WILL rub!
Old Mar 18, 2010 | 11:32 PM
stnwag0n's Avatar
should i get a spring that wont lower as much, like the h&r sport for sedans?
Old Mar 18, 2010 | 11:39 PM
I don't rub right now with 255/35/19 in the back but I have some negative camber -2.5 I believe. I need a rear camber kit to save my tires and then roll my rear fenders and throw 10mm spacers in the back
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Soumilg
Jul 18, 2015 12:33 PM
