upper control arm rubbing on a lowered 04 g35 coupe neede help
Old Apr 16, 2010 | 12:58 PM
paolotonzini's Avatar
i have a 04 g35 i bought it lowered and noticed the inner part of the front wheels were wearing at a way faster rate so i installed the ACP upper adjustable arms and it seems i cant get enuff camber adjustment because the spindle or what ever the part that conects to the next control arm ends up rubbing on the inner fender wall if i try and adjust it to correct the camber (more positive), has any one had this issue when lowering there g's and how did you correct it to get the tires to wear at an even rate thank you.
(so to sumerise my upper control arms cant be adjusted to a positive enuff camber with out rubbint on the inner funder)
Old Apr 16, 2010 | 01:05 PM
GreenGoblin's Avatar
The goblin resurrection
This is because of simple geometry, at a certain point you are dropped to low for the width of the wheel to fit with 0 camber.
Old Apr 18, 2010 | 05:18 PM
so does this look too agresive to get back to a 0 camber? (attached pic is my car)
Attached Thumbnails upper control arm rubbing on a lowered 04 g35 coupe neede help-user90203_pic16825_1250354973.jpg
Hasanbaloch
Feb 29, 2024 08:45 PM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
teamghost
Jul 28, 2015 04:52 PM
Soumilg
Jul 18, 2015 12:33 PM
