toe & camber
Old May 3, 2010 | 09:55 AM
jonchavi's Avatar
toe & camber
I have a 03 g35 coupe I put lowering springs and camber kit the front is perfect but the back if I set the camber it throws off my toe if I set my toe it thows off my camber what am I missing?
Old May 3, 2010 | 05:39 PM
Canadian G's Avatar
What toe and camber numbers are you trying to achieve? Did you install aftermarket toe bolts with your camber kit?
Old May 4, 2010 | 10:35 AM
jonchavi's Avatar
The camber kit did not come with bolts do I need to get them sepret and where can I find them
Old May 4, 2010 | 10:42 AM
GAU-8's Avatar
yes. Toe and camber are equally affected when changed. If you alter camber, toe is equally affected.
Old May 4, 2010 | 01:45 PM
A.Chambers's Avatar
Firestone was able to get me in spec with just the camber arms. Dont have the paper in front of me but the toe is at 0 and well within camber spec. 1.5" drop 350z eibach pro kit
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Rose M
Oct 12, 2015 10:00 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
