Ok??? How do i remove this???????????? Help!
Old May 20, 2010 | 01:25 PM
AARONHL's Avatar
How do I remove this compression rod? I've tried to heat the sleeve with a propane torch and chisel the top, but no luck!!! Looking for tips, tricks, or someone to come to my house and yank it off!!
Old May 20, 2010 | 01:30 PM
AARONHL's Avatar
My G is currently up in the air...so if anyone could give me a fast reply I would appreciate it!!!!!!!!!!!!!!!!!!!!
Old May 20, 2010 | 01:37 PM
miltoda's Avatar
Are you trying to remove/replace the bushing? If so, take the whole rod off the car, and take the rod to a shop (or if you have one yourself) that has a hydraulic press to remove the bushing and also press a new one on. Hope this helps!
Old May 20, 2010 | 01:52 PM
AARONHL's Avatar
Yes.......I can't take the rod off the car!
AARONHL's Avatar
It's rusted on!!!
Old May 20, 2010 | 01:54 PM
G35Papa's Avatar
Start spraying some PB Blaster on there and let it soak...then in 10 minutes, get a rubber mallet and give it a few wacks
Old May 20, 2010 | 01:56 PM
AARONHL's Avatar
Thanks for the reply. I've tried that, but I'll try it again. What's the best place to SMACK it? Because when you hit the actual rod, the bushing cushions. The sleeve inside the bushing is what's rusted to the bolt.
Old May 20, 2010 | 02:52 PM
AARONHL's Avatar
This is riiiiiddiculouuuuuuuuusssssssssssssssss
Old May 20, 2010 | 03:08 PM
AARONHL's Avatar
Not working!!!!! WTF
Old May 20, 2010 | 04:27 PM
AARONHL's Avatar
Still NO luck!
Old May 20, 2010 | 04:54 PM
AARONHL's Avatar
I just put the car back on the ground without the nut and mounting bar NOT attached. Didn't slide off...could this get ugly???
Old May 20, 2010 | 04:56 PM
Neu Era's Avatar
Keep whacking it, did u take the pin out from the top?
Old May 20, 2010 | 05:03 PM
AARONHL's Avatar
Could probably go for a drive without the nut!!!
Old May 20, 2010 | 05:04 PM
AARONHL's Avatar
Whack what part of it? And what pin are you talking about?
Old May 20, 2010 | 05:14 PM
AARONHL's Avatar
