Rear Brembo conversion on sedan
Old May 20, 2010 | 10:45 PM
mgene63's Avatar
Does anyone know what is needed to install the stock brembos from the sport onto the sedan? Or if it can be done at all?
Old May 20, 2010 | 10:56 PM
STCLAIRWEST's Avatar
I think its a direct fit
Old May 20, 2010 | 10:57 PM
SDGenius's Avatar
you just need the Brembo caliper bolts
Old May 21, 2010 | 10:10 AM
mgene63's Avatar
Just to be sure are the rotors the same?
All I should need are
Brembo Calipers
Brake Pads
Mounting bolts
Old May 24, 2010 | 04:24 PM
mgene63's Avatar
So from the research I've done I'll also need new rear rotors as they are bigger.
I also found out that the master cylinders between the sport and regular are different sizes, has anyone changed to the larger size?
Old May 24, 2010 | 04:25 PM
mgene63's Avatar
it also looks like the rear break lines are different.
Old May 24, 2010 | 04:40 PM
Jeff92se's Avatar
Red Card Crew
What are you doing for the fronts? I can't see a rear bbk only swap helping anything but to make you do 180s.
Old May 24, 2010 | 04:53 PM
mgene63's Avatar
I have Project Mu BBks up front, I just found the rear brembos for a good price and thought it would round things out nicely
Old May 24, 2010 | 04:59 PM
Jeff92se's Avatar
Red Card Crew
You need to figure out of the increased bias to the rear is going to screw up the front/rear bias values.
Old May 24, 2010 | 05:22 PM
mgene63's Avatar
I would figure that they are already screwed up having the bbk installed and would assume that adding the rears would actually bring it closer to where it should be. Either that or I should really install the Sports master cylinder too which is already biased for 4pot front 2 pot rear. But then that brings up the issue of the break booster and if it would be worth it to change that as well since it is different also.
Really I think that I have change anything but the rear brakes/rotors/lines.
Old May 24, 2010 | 05:26 PM
Jeff92se's Avatar
Red Card Crew
Not all front only bbks are poorly designed. Stop tech has a front only kit that's designed around only being a front only kit.
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
yoyoyo8
Aug 12, 2015 03:04 AM
teamghost
Jul 28, 2015 04:52 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
mushu
Jul 15, 2015 03:55 PM
