just had front endlinks changed at dealer and now..
Old May 27, 2010 | 08:01 PM
prelude9569's Avatar
just had my front connecting rods/ endlinks changed at the dealer b/c the front end was clunking and now my suspension feels mushy. If I jerk the wheel to the right or left quickly the rear end feels like jello and not very solid,lot of body roll, almost like my rear tires are flat kind of feeling.
Old May 28, 2010 | 06:51 AM
Blue Dream's Avatar
I drove ttrank's car solo
Ok???
Old May 28, 2010 | 08:21 AM
Swivel's Avatar
Moderator
But it was tight before? Do you have adjustable sway bars or stock? Maybe they reconnected them in the softest setting. Did they forget to connect the rear altogether?
Old May 28, 2010 | 11:55 PM
yes it was tight before i had the connecting rods replaced and everything is totally stock. its a 2008 journey sedan. i plan on bringing it back to the dealer soon to have them look at it again. if they say this is normal, which i do not believe they will, but if they do i guess it will be time to at least change all the sway bushing to polyurethane for starters and then onto aftermarket sways both front and back??
are there different settings on stock sway bars?
Old Jun 2, 2010 | 03:41 PM
sloppymax's Avatar
OEM bars are not adjustable. If you want to skip the dealer, I would just check that they were torqued down properly. I would not spend money on polyurethane replacements for the stock bars because if they exist they will not fit the thicker aftermarket bars if you go that route.
Frankieg35
Mar 20, 2016 09:42 PM
tiguy99
Mar 1, 2016 11:42 AM
neight
Steering & Suspension
Aug 7, 2015 02:48 AM
kinetek
Aug 3, 2015 04:25 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
