rotor thickness
Old Jun 30, 2010 | 04:39 PM
whoisthis's Avatar
rotor thickness
i recently checked my brother's g35 rotor thickness. The thickness for the front was 1.057 in and rear .614 in. He bought the car used like 2 yrs ago and the rotors came with it. According to FSM, the std thickness for front is .433 in and rear .335 in. Although his rotors are used, they are much thicker than the std ones. So i'm guessing these are aftermarket parts. But how do i know when to change the rotors?
thx guys.
Old Jun 30, 2010 | 04:42 PM
Jeff92se's Avatar
Red Card Crew
The min thickness should be stamped on the rotor.
But it looks like he's good to go.
You change them when they get to the min thickness
Old Jun 30, 2010 | 04:51 PM
whoisthis's Avatar
are they stamped on the back of the rotor? i would not want to take out the rotor just to check it out lol
Old Jun 30, 2010 | 04:56 PM
Jeff92se's Avatar
Red Card Crew
Either on the inside of the hub (yeah, you'd have to take them off) or on the outside rim of the rotor. (you could just take the wheel off)
Old Jun 30, 2010 | 05:06 PM
whoisthis's Avatar
i have a quick question. if i were to buy a aftermarket rotor that is .5 mm bigger in outer diameter, is it ok with stock brake caliper?
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
9tray turbo
Sep 29, 2015 10:22 PM
