Trouble with wheel bearing on g35x
So i have a blown front wheel bearing on my 2004 g35x, i had everything around today, had the 4 bolts holding the hub assdembly to the knuckle out but the hub would NOT budge. It's as if it was rusted to the knuckle, i tried almost everything to get it off, pb blaster, tourch, chizel, nothing worked so i basicly gave up.
Any ideas? anyone have this same issue and find a way to get it off? A friend of mine said go to autozone and rent a hub puller, think that this would deffinitly work?
ENVautoDetailing.com
Just a common sense question but needs to be asked...
You have an X (AWD) did you happen to take off the big nut (32mm IIRC) holding the axle to the hub??? You would need to remove that and the 4 bolts holding the hub to the knuckle to remove the hub.
When I did the rear wheel bearings on my RWD G, my bearing was seized in as well. I ended up using slide hammer. A few pulls on the slide hammer and it fell right out. I just had to keep working my way around the bearing to get it to nudge it out.
Heres a picture...
Heres a picture...
True.
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
