shocks and strutts
Old Jul 17, 2010 | 06:02 PM
Vince Bryant's Avatar
shocks and strutts
My 04 sedan just turned 100K miles. I would like to change my rear shocks and front struts. As I travel for a living, ride quaility is a priortiy over handeling allthough , I would like less body roll in the corners. Any suggestions on a good shock and strutt for my ride?
Old Jul 17, 2010 | 06:52 PM
Xet's Avatar
Xet
It really depends on how much you are willing to spend and how much quality you are willing to give up. There are plenty of great adjustable shocks out there but I don't know personally if even on full soft they will compare to the comfort of oem sedan struts.
Old Jul 17, 2010 | 07:12 PM
brandon1978's Avatar
Go with the Tokico D-specs (~$525) and you can set the dampening exactly how you want it. On the sedan you can change the settings in under 10 minutes, so you could even soften it up for long trips. The adjustment ranges from way-to-stiff (for the street) to softer than OEM. With 100k miles, your dampeners are so worn, that there would be a big improvement just getting new OEM units or Tokico HPs (non adjustable). BTW: Tokico also makes our OEM units. I replaced my OEM units with D-specs at 50k.
Old Jul 18, 2010 | 08:57 AM
thanks for the tip guys!!!!
Old Jul 18, 2010 | 08:07 PM
EL-EE-ES's Avatar
yes tokico d-specs, as for body roll a set of sway would help...
Marlin84
Apr 1, 2020 12:52 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
g.spot
May 9, 2016 10:54 PM
NyCrAzY
Oct 1, 2015 09:19 AM
TheBay
Sep 3, 2015 03:27 PM
