Rear rubber cone with aftermarket coilovers?
Old Jul 23, 2010 | 12:26 AM
VicariousVision's Avatar
Quick random question - should the OEM rear rubber cone that is on the spring be used with aftermarket coilovers on the coupe? I found where it is NOT used on the 2nd gen coupes/sedans, but I did not see anything about the first gen coupes. Could someone please confirm for me?
Old Jul 23, 2010 | 12:12 PM
Xet's Avatar
Xet
I'm assuming oem style, if so you take out the rubber cone since that is where you put the stand where you adjust height. If you search around some of the diy's you can see some pictures of what I'm explaining.
Old Jul 23, 2010 | 03:03 PM
bjquinnIUmed's Avatar
No need for the top OEM rubber springmounts. They are replaced by the adjustable height perch with the coilover. If I remember correctly, you do generally reuse the lower springmount (but I can't remember if there's even one there or not).
derres
Aug 28, 2015 03:27 PM
TreeFiddy
Aug 10, 2015 06:50 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
