Compression rod nightmare. Snapped bolt. FML
Old Jun 2, 2014 | 01:54 PM
MDave's Avatar
My compression rod seized too. Got it off by cutting off the outer metal casing and rubber, then heating the seized metal with a torch. Took 5 minutes with a weak torch after cutting the casing.
http://i1333.photobucket.com/albums/...ps5e9c27c1.jpg
Old Mar 14, 2019 | 06:47 PM
maoliveras's Avatar
g35 coupe base
This happened to me
where are you located no shop will do this for me. Could you do it for me I’d pay 😂 where u located. Or give better instructions
Old Mar 14, 2019 | 11:03 PM
cswlightning's Avatar
If all that happened is your stud snapped off you just need to find a guy on Facebook locally who will weld on a new 12.9 or 10.8 bolt of similar size and thread pitch (along with a corresponding nut obviously) and do it right.... That involves grinding bolt studs down to arrow points with decent sized flats in order to get as much weld area as possible. If you can get it anywhere near spec it'll probably hold up fine, mine has and my car's been beat since. My guy charged me I think $120 but this is by no means an easy job and we already had a relationship.
Nobody wants to do it for liability and insurance reasons, you gotta find someone who doesn't care about that or DIY.
Old Mar 16, 2019 | 05:13 PM
Urbanengineer's Avatar
Yep! It sucks man but it's time To go custom.
Old Dec 4, 2019 | 12:11 PM
Luig35's Avatar
smooth rebuild
That bolt is welded into the frame
I broke mine too and then came up with some brilliant idea to put them together with a cupling nut and since then I had 20k miles no problems.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Danielek
Sep 18, 2015 12:16 PM
