Tanabe df210 springs
Old Aug 24, 2010 | 03:00 AM
autobot's Avatar
Couple quick questions. Installed Tanabe lowering Springs.
1. Can the camber be adjusted at all on the stock suspension?
2. What is toe? Can it be adjusted on the stock suspension?
3. Is it worth it to get an alignment on the stock suspension after the drop or should I wait till I have purchased and installed camber kits?
Old Aug 24, 2010 | 05:22 AM
(Stealth Inc.)'s Avatar
1. yes, but not back to spec
2. don't know
3.do it right the first time you'll save more money in the end . get coilovers camber kits front and back and alignment.
BTW, i used to have df210 also but i didn't like the ride quality felt kinda soft that's why i say go with coilovers you could also go lower with coilovers if you wanted to.
Old Aug 24, 2010 | 07:52 AM
EL-EE-ES's Avatar
1. only on the rears, as stated above "not into spec"
2. toe is angle of the wheel front to back. this well eat you tires up if not into spec. you can only adjust it so much on stock suspension.
3. id get a camber kits with the df-210.
Old Aug 29, 2010 | 03:20 AM
autobot's Avatar
Thx for the help!
DRG35R
Jan 31, 2016 07:14 AM
prinny
Nov 22, 2015 11:07 PM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
