Installing Coilovers and Camber Arms
Old Sep 17, 2010 | 02:58 PM
lil beezy's Avatar
thanks, that is helpful! i cant find anything on if i have all the correct parts?
also, i cant find anything on just the rear assembly of the coils i got?
Old Sep 17, 2010 | 03:22 PM
Blue Dream's Avatar
I drove ttrank's car solo
You will re-use all of your stock nuts and bolts for the installation. Your front coilovers should already be completely assembled and ready to install. If your rears are "OEM style" the strut and spring will be separate so just swap out the strut and take out your upper springmount and put the metal spring perch that came with your coils on top of the spring up against the chassis. You will use this to adjust the height of the rear.
Old Sep 18, 2010 | 12:36 PM
lil beezy's Avatar
Thank you sooo much!!! That really helps. That would still leave me with one part though, it kinda looks like the spring perch, but it has a rubber piece on one side, but it's not flat?
Old Sep 18, 2010 | 01:35 PM
Blue Dream's Avatar
Post a pic as I'm not sure what you are talking about.
Old Sep 18, 2010 | 01:41 PM
gambit2083's Avatar
Ha I didn't either. I have since seen that some front coils are labeled L or R but mine weren't. The brackets for the brake lines don't line up correctly if the coils are on the wrong side.
Did the same exact thing when i put in my sportlines, got done and was like wtf...followed by a charlie brown scream
Old Sep 18, 2010 | 04:52 PM
lil beezy's Avatar
this part...
lil beezy's Avatar
http://s61.photobucket.com/albums/h4...-18at13473.jpg
Old Sep 18, 2010 | 05:24 PM
Blue Dream's Avatar
Sorry lil beezy I don't have a clue. Someone else chime in?
Old Sep 19, 2010 | 03:07 AM
lil beezy's Avatar
or does anyone know how i can get a rubber stopper looking piece from megan?
jsimonk
Dec 22, 2023 03:49 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
cbax
Aug 17, 2015 07:41 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
