HELP with removing front hub
Old Sep 11, 2010 | 03:27 PM
culi's Avatar
I need help removing the front hub. I have removed the four bolts on the back of the hub. Now the hub won't come off. Is it because of rust? I tried using the mallot and it still won't come off. Is there another bolt somewhere that I'm missing?
Attached Thumbnails HELP with removing front hub-img00412.jpg   HELP with removing front hub-img00413.jpg
Old Sep 11, 2010 | 05:01 PM
the_sedan's Avatar
just the 4 bolts in the back, make sure u take the speed sensor out on the side too. and air chisel is what i normally use to get between the hub and the knuckle.......if you dont have that, get a big screwdriver or get a big chisel and hammer away between to get them to separate. sometimes just hammer on the backside of the hub itself (the portion with the studs) and itll come forward.........
Old Sep 11, 2010 | 08:31 PM
culi's Avatar
Well after an hour of fighting it and hammering the crap out of it from behind, it came out.
Old Sep 11, 2010 | 09:00 PM
the_sedan's Avatar
yeah they are in there pretty good. thats why air tools are so much better lol. make sure you clean the surfaces up with sandpaper or something too as you can see whatever dirt/rust/oxidization on the bearing and knuckle before puttin it back together
Cajuncowboy
Jun 21, 2021 09:47 AM
TL2G35x
Aug 12, 2015 10:30 AM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
wuppiedog
Aug 7, 2015 11:16 AM
papo020
Jul 17, 2015 10:30 PM
