Quick help from you suspension experts! '07 6 spoke coupe wheels installed
This is about an alignment but I'd figure it may be worthy to note my wheel setup. I recently bought and installed '07 coupe wheels and tires on my car and got an alignment. Wheels are staggered fyi. There are a few questions I had after I got an alignment. First, the shop couldn't get the toe and camber perfect. They mentioned that I need new control arm bushings and possibly a camber kit. If this is the case, this is what I planned on purchasing:
Would these help get my alignment into spec?
WHEEL SET UP:
FRONT: 225/50/17 7" 6 spoke
REAR: 235/50/17 7.5" 6 spoke
WHEEL SET UP:
I'm on all stock suspension (non-sport '03.0). '07 coupe wheels: 225/50/17 7" and 235/50/17 7.5". My car squeaks a lot more, I feel like I have more understeer with a staggered set up.
Stock suspension you should be able to get back in spec without aftermarket parts. And what was out of spec (camber, toe, caster) and on which wheels? If you want to get a rear camber kit get the ichiba or spc kit with the toe bolts.
rezendvous420
May 31, 2020 01:26 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
kinetek
Aug 3, 2015 04:25 PM
