Just installed KSport pro kit
I started the install on saturday afternoon and finished on monday night (after work). I gave up all my football watching time this weekend to install the kit. The install went smooth. All my power source was easy to tap into thanks to my amps in the trunk. Actually, the planning process was harder than the actual install. KSport makes an excellent kit and I love this kit!!
gauge/switches installed in coin tray
front strut
rear setup
tank setup
mounted the wireless remote brain next to the tank
mounted the relays behind the spare tire. The wiring leads to where the stock amp is mounted
mounted air line with some extra just in case
final tank setup in trunk
the final product on monday night
front strut
rear setup
tank setup
yes, the kit uses all new struts. that's actually one of the reasons that my friend recommended this kit. The install was not difficult at all. When they said that this would be bolt on, they really meant it. If you can install coilovers, you can pretty much install this kit. The most time consuming part was figuring out a way to run the lines and what sources to use when wiring the relays/valves. The struts do have 36 way damping adjustability. I highly recommend this kit. Here's the features straight off of K Sport's page:
Key Features
1. 1 – 5gal air tank 9 port
2. 2 – Viair 380c compressor, 200psi 100% duty cycle
3. 1 – 200psi pressure switch
4. 1 – Silencing base plate
5. 2 – electronic switches
6. 1 – 200psi dual needle gauge
7. 1 – Bracket for gauge and switches
8. ¼” high pressure air line
9. Power Wire
10. 1 – Fuse Box
11. 4 – Full Struts with adjustable lower mount, aluminum top mounts, and 36 levels of damping adjustment
12. 4 – High pressure airbags
13. 4 – electric Solenoids
14. 2 – ¼” Valves
15. Wireless remote control
Key Features
9. Power Wire
10. 1 – Fuse Box
14. 2 – ¼” Valves
