Do these pads fit the G35 Coupe?
I have an 03 Coupe and I put in brand new pads and rotors on all 4 corners about 4 years ago when the car had 50k miles. It has 109k miles now and the rears have just started squeaking. During my last oil change the pads were measured at 7mm in the front and 3mm in the rear. Should I go ahead and replace the fronts as well if I am going to do the rears? I plan on using the same rotors I put in at 50k mi. They are drilled and slotted rotors.
Also, do these pads fit the G coupe?
It says they fit the sedan, does that mean they fit the coupe as well?
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
