Cost effective alternative to Brembo setup? Maybe Wilwood?
Old Oct 9, 2010 | 07:41 PM
itgogitrev's Avatar
For 2 months I've been scouring the boards/ebay/CL/salvage yards for some Brembo calipers. My 04 sedans brakes need to be replaced and I can justify spending the money on the upgrade since I'm swapping out old, worn out stuff.
However, I'm seeing Brembos going for $1500-ish and I can't bring myself to spend that on used calipers. Not saying they aren't worth it, I just don't see where the money is going when they're scratched up, dented, etc...
Is there an aftermarket caliper that will work with either the later G35 rotors or Brembo rotors? I've had great luck with Wilwood in the past, but I don't see too much stuff out there for Zs/Gs unless it involves a larger rotor.
The reason why I want to stay with stock rotor sizes is because I'm running 17x9 wheels for auto-x.
Old Oct 9, 2010 | 08:18 PM
VstyLe09's Avatar
http://www.arizonazcar.com/350zbrakes.html
i know the 5zigen fn10r-c 17" fits under those wilwood with 13" rotors..depending on the offset that is.
Old Oct 9, 2010 | 10:26 PM
itgogitrev's Avatar
While those are REALLY nice, that is a LOT more than what I'm looking to spend. Looking for 1 piece rotors w/ a 4 piston front, 2 piston rear. Pretty much a true Brembo alternative. 2 piece rotors are really cool and would be great if I was doing more tracking, but it's really overkill for auto-X.
Plus, moving out of stock rotor sizes and near-stock caliper specs will push me out of my current class.
Old Oct 9, 2010 | 11:17 PM
Todd TCE's Avatar
Because most of the market revolves around larger 13-14" rotors your goals are going to be a bit tough. I'll tell you that rotor size has more value than simply replacing a caliper on the stock rotor....but if a "caliper kit" is truly all you're looking for you might check with Brian at Fastbrakes and see what he has to offer you.
Old Oct 9, 2010 | 11:21 PM
itgogitrev's Avatar
Thanks Todd. I'll give him a look and see what he can do. Normally, I'd take off the calipers and measure them, then fabricate brackets to make the replacement calipers work, but I'm on a huge time crunch this time around.
Old Oct 9, 2010 | 11:26 PM
SDGenius's Avatar
they make Wilwood caliper kits that bolt directly onto the OEM 05-06 rotors
Old Oct 10, 2010 | 12:25 AM
itgogitrev's Avatar
^^^ Front and rear, or just fronts? Who is 'they'? Fastbrakes?
Old Oct 10, 2010 | 12:35 AM
SDGenius's Avatar
front and rear on ebay...
front>>> http://cgi.ebay.com/ebaymotors/Big-B...#ht_2381wt_939
rear>>> http://cgi.ebay.com/ebaymotors/Big-B...#ht_1853wt_939
just front calipers>>> http://cgi.ebay.com/ebaymotors/Big-B...#ht_2045wt_939
Old Oct 10, 2010 | 12:36 AM
Neu Era's Avatar
Hmmm good stuff.
Old Oct 10, 2010 | 02:17 AM
itgogitrev's Avatar
Out of the ebay ones listed, I can do the front caliper kit but I can't do 13" f/r because the rotors are larger than stock. It'll put me in a class where I won't be competitive. The rules were changed recently where I can use any stock sized rotor and equivalent caliper in terms of piston quantity throughout the generation (including facelifts).
Otherwise, a 13" rotor would be fine. But in this case, it would put me up against modded EVOs, STIs, and Z06s... and I have a hard time dealing with near stock EVOs and STIs already.
Old Oct 10, 2010 | 12:22 PM
Todd TCE's Avatar
So you're back to the "caliper kit" for the oe rotor then? I'm sure I could help you with that but if you're under a serious time crunch I'd keep looking for a bit. And you shouldn't be paying more than about $450 max for it if it's an FSL based kit.
Old Oct 11, 2010 | 04:13 AM
itgogitrev's Avatar
Never really left it.
I took my calipers off today and measured them. I'm just going to fab some brackets and get some Wilwoods that closely match the specs of the Brembos.
Old Oct 12, 2010 | 03:38 PM
eric cartman's Avatar
Stay away, far away from those eBay Willwood setups. I had one on my old Sedan, they stopped well, only if you could deal with the noise. Not just little groans or squeaks, but loud squeals. I tried various pads/rotors, with no avail. I eventually just ditched the setup at the time I sold the car. They were quiet if you were really hogging down on them,but waaaay too noisy if you're just gently normal driving.
Old Oct 12, 2010 | 09:26 PM
itgogitrev's Avatar
Thanks for the heads up. It sounds like they might've sold you a really hot pad.
Been doing a LOT of math lately and I think I might have a solution. Once I get it working, I'll post pics.
EasySausage
Sep 24, 2015 01:06 PM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
Detailed Image
Sep 4, 2015 08:35 AM
TheBay
Sep 3, 2015 03:27 PM
