Driver Side Front cracking/clicking noise
Old Oct 11, 2010 | 02:53 AM
nate704's Avatar
Here's the situation.
engine running in the parking lot and you are trying to turn your steering wheel to the left about one turn, and as soon as you start turning the steering wheel to the right, you hear loud cracking/clicking noise along with some rubber rubbing/squeeking noise coming from the left front side of the car.
Compression rods and sway bar end links were replaced about two weeks ago.
Should I try lube those bushings with silicon grease first?
Or could this be the problem with other suspension parts?
let me know. thank you guys in advance!
Old Oct 11, 2010 | 08:10 AM
nate704's Avatar
anyone?
Old Oct 11, 2010 | 02:55 PM
nate704's Avatar
i guess i gotta take it to the dealers
Old Oct 12, 2010 | 02:10 AM
SAM45G35's Avatar
I have a similar issue with my 35...does it also make a noise sometimes when you push the breaks?
My tech guy advised to replace ball joints, compression rod bushings, and LCA bushings....
I will be driving my 45 until i get this taken care of also!
rezendvous420
May 31, 2020 01:26 PM
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
attarday
Jul 15, 2015 04:03 PM
