How do you bleed the ABS system?????
Old Oct 16, 2010 | 12:09 AM
nctrnlsilvia's Avatar
I think I have air in my ABS system,someone told me to bleed my ABS as well as my brakes. Already bleed my brakes twice and still have the glitching and pumping when I brake.
Old Oct 16, 2010 | 10:11 AM
Mustang5L5's Avatar
More than likely, you have a failing abs wheel sensor which has not sent an abs code yet. They sometimes get metal shavings and curb on them which messes up the signal. You might need to remove and clean and inspect the wheel sensors.
Bleeding abs is no different than regular brakes.....unless you let the system run dry. If thensustem activates the abs when not needed, you perhaps have other issues
Old Oct 16, 2010 | 02:24 PM
Thanks, im going to check it out.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
