Which springs give you lower drop?
Which S-Techs will give me a lower drop on a G35. The 350Z ones or G35 ones?
Tein S-tech 350z (fronts are progressive, rears are linear) .7”/.6” drop on 350Z G35 drops will be higher
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Tein S-tech G35(fronts are progressive, rears are linear) coupe drop 1.2"/.9" sedan drop 2"/1.3"
Spring rates in LBS 358/274 (final rates only, softer intial front progressive rate unknown)
Tein H-tech 350z linear springs .3”/.2” drop on 350Z G35 drop will be higher
Spring rates in LBS 358/375
Tein H-tech G35 (fronts are progressive, rears are linear) coupe drop .6"/.3" sedan drop 1.4"/.7"
Spring rates in lbs 324/260 (final rates only, softer intial front progressive rate unknown)
I'm on 350Z H-Tech at the moment.
It looks like front G35 S-Tech have a same spring rate as front 350Z H-Tech
Maybe I should just put on G35 S-Tech on the front and drop rear by cutting rubber mount.
I don't really like other options, they make my rear end too soft or to stiff and make it slide all over the place.
Whatcha think?
Whatcha think?
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
Dundermuffin666
Aug 14, 2015 04:01 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
