caliper wearing
Old Nov 26, 2010 | 12:40 AM
matthew23's Avatar
caliper wearing
Is there any tests you can do to see if your calipers are wearing out?
Old Nov 26, 2010 | 12:43 AM
4DGS's Avatar
what makes you think they are?
Old Nov 26, 2010 | 12:48 AM
matthew23's Avatar
theres some rust on the outside edges on the rear and when I drive it shakes in the front a little bit when i push the breaks. any ideas?
Old Nov 26, 2010 | 12:52 AM
4DGS's Avatar
Not calipers.
The rust is probably normal, it is in a busy spot of the car. Post a pic.
The shaking is probably a warped rotor or unevenly warn pad.
Old Nov 26, 2010 | 01:04 AM
matthew23's Avatar
ill post a pic tomorrow. come to think of it they are warped unevenly. should i just replace those first then if that doesnt work the calipers? from what i know theres really no way to test a caliper other than taking it off and taking it to a shop.
Old Nov 26, 2010 | 01:35 AM
4DGS's Avatar
I highly doubt the caliper is shot. Just do pads and rotors and you'll be good.
How many miles on your car?
Old Nov 26, 2010 | 03:16 AM
socialconflicts's Avatar
yup, your rotors, usualy the vibration happens when braking. you will be able to feel it on ths steering wheel. you either A) need to resurface your rotors or B) get new rotors... and obviously new pads :P
good luck sir!
Old Nov 26, 2010 | 08:32 AM
matthew23's Avatar
cool thanks guys! My car has 100,000 miles on it and they've probably never been changed. Ill keep you guys updated on how it goes. is there any that you guys would prefer?? I noticed theres different kinds like 4 piston and such. This may be a silly question but im kind of new at this stuff and love learning about it but how do i tell which ones i need? thanks again guys!
Old Nov 26, 2010 | 10:06 AM
semicycler's Avatar
Originally Posted by matthew23
... and when I drive it shakes in the front a little bit when i push the breaks. any ideas?
Shakes only when braking? Likely rotors or pad wear as others say.
If it shakes all the time, check your wheels - air pressure, rebalancing, odd tire wear, etc. Likely tires if the shaking changes when the tires warm up.
Old Nov 26, 2010 | 10:15 AM
4DGS's Avatar
^ yea it's only breaking
I'm willing to bed that in 100k (160kms) that the brakes have definitely been done. If they haven't then you bought a total heap of ****.
Old Nov 27, 2010 | 10:27 AM
matthew23's Avatar
sweet thanks guys! im going to just switch all pads and rotors this week. What are some good rotors to buy that will last a long time?
Old Nov 29, 2010 | 11:50 AM
G35fromPA's Avatar
Centric premium rotors are very high quality at a decent price. Can get them from rockauto.com or tirerack.com.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Jeff T
Sep 30, 2015 02:00 PM
