Brakes fade. What is the least expensive, best fix?
Old Nov 26, 2010 | 09:05 PM
zanlin21's Avatar
I just bought a 2006 G35 6spd coupe. It only has 30K miles on it and the brakes fade pretty bad when they get hot. I'm sure this is a common problem and would like to some feedback from other who have found a fix for this (without spending too much money). The car has 19 inch rims and I beleive that increasing the rotor size would definetatly help as the heat would have more of a surface to dissipate. Does anyone know of any kits that would include larger rotors, stainless brake lines and an adaptor for calipers (that doesn't cost 3K). Is replacing the calipers a must?
Old Nov 26, 2010 | 09:11 PM
SDGenius's Avatar
2pc rotors could help but there aren't a lot of options(if any) for your particular year.
Old Nov 26, 2010 | 09:17 PM
Heist.'s Avatar
my brakes on my 03 suck. I'm in the same boat. Nothing seems to be a cheap fix though.
Old Nov 26, 2010 | 09:57 PM
SDGenius's Avatar
i solved this problem w/used Brembos
Old Nov 26, 2010 | 10:19 PM
VQdriver's Avatar
Are you a hardcore roadracer? The least expensive fix: bleed fluid with Motul or ATE Superblue brake fluid. Next after that would include better pads (there's a wide variety), rotors and stainless lines. The best fix is used brembos, G37/Z34 brakes, or BBK. If I had my pick I'd look into Racingbrake/Wilwood or Stoptech each because replacement pads/rotors are plentiful. It's not cheap however.
Old Nov 26, 2010 | 10:26 PM
zanlin21's Avatar
Thanks for the responses, has anyone tried the Trinet cross drilled & slotted rotors?
Old Nov 28, 2010 | 01:03 PM
SDGenius's Avatar
these would probably be your best bet w/o actually upgrading calipers>>> https://g35driver.com/forums/brakes-...g-wonders.html
Old Nov 29, 2010 | 10:50 AM
G35fromPA's Avatar
I'll 2nd VQDriver's advice. Replacing the brake fluid is your first and cheapest option to try and may do the trick. Frequently fade has more to do with boiling fluid than overcooked pads or insufficient rotors. If higher temp fluid fails to do the trick, then think about higher temp pads, slotted rotors, etc. BTW, SS lines won't really reduce fade, they'll mainly affect pedal feel.
Terry_G35
May 9, 2020 01:39 AM
miata007
Aug 17, 2015 04:36 PM
helalo
Aug 10, 2015 08:21 AM
Terry_G35
Aug 4, 2015 02:38 PM
emorehs
Jul 17, 2015 09:45 AM
