Wheel Spacers Question
Old Dec 2, 2010 | 02:13 PM
Gspot82's Avatar
Hi guys i was wondering if its better to have same size of spacers all around or 20mm front/25mm back. Sorry i am just really dont know which rout to go. Thank you for your help !!
Old Dec 2, 2010 | 02:15 PM
CandlestickPark's Avatar
ill Sedan
Need some more details. What are the specs of wheels (widths/offsets)? What tire sizes are you running? How low are you? Coupe or Sedan?
Old Dec 2, 2010 | 02:24 PM
lsmooth81's Avatar
It depends on the offsets of your wheels and the look you want. Usually your rear spacer size are higher to get the wheels to sit flush with the rear fender, which seems wider then the front, but the numbers depend on your current wheels offsets. You don't want to put 20/25mm spacers if you have low offsets. Use the link below to get an idea of the look you want and compare offsets with what you have and subtract the spacers size from your current wheels offsets to give you that low offset look.
For example if your wheels offsets are 30/35 and you get 20/25. Then subtract 30-20=10 for front and the same for the back and you will have the appearance as someone who has the same wheels with the offsets of 10mm in the front and rear. Hope this makes sense.
http://rimtuck.com/thumbnails.php?ve...del=G35+coupe&
Old Dec 2, 2010 | 02:26 PM
lsmooth81's Avatar
Marcus is right those are other factors to consider.
Old Dec 2, 2010 | 03:52 PM
Gspot82's Avatar
I am soo sorry. lol. Its for a 06 coupe with oem 18". Im planning on just keep the 18" and G tein Htech. Thank you
Old Dec 2, 2010 | 09:50 PM
Xet's Avatar
Xet
Neither are really better than the other, it depends on what look you are going for.
Old Dec 3, 2010 | 03:16 PM
Gspot82's Avatar
Well i just want a really mild drop since this is my DD car.
Old Dec 3, 2010 | 06:45 PM
Xet's Avatar
Xet
You want a drop out of spacers?
Old Dec 3, 2010 | 09:07 PM
Gspot82's Avatar
Hahahah... Noooo sorry for the confusion. I want a mild drop with some good spacers
Old Dec 5, 2010 | 03:40 PM
adamls2's Avatar
I say 25mm all around...thats what i did but im going with df210 springs which are lower
Old Dec 5, 2010 | 07:25 PM
Xet's Avatar
Xet
I'm pretty sure oem 18 are similar to oem 19 in terms of offset and the likes. I would go 25mm all around, I did that with my oem 19's and enjoyed it. I would possibly have even gone 25f/30r if I didn't plan on dropping lower than my zhtechs.
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Soumilg
Jul 18, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
