Premature tire wear on 03 Coupe?
Old Feb 24, 2012 | 12:44 PM
destroid's Avatar
The rears wear about twice as fast as fronts. However I've always been able to get at least 20,000 miles from each set of RE050A rears. Mostly highway driving.
Old Feb 24, 2012 | 01:01 PM
nghiars's Avatar
Those are definitely normal and not bent from an impact.
agreed
Do you have the alignment spec sheet from the dealer when you got it aligned last time? Possibly the dealer isnt putting it into spec.
Old Feb 28, 2012 | 09:15 PM
G35fromPA's Avatar
Originally Posted by miketyler
went out and snapped a pic, somehow they look even more bent than I remembered. The lowest links are the ones I am talking about. They are supposed to be straight, right?
Hard to tell for sure. The Field Service Manual shows that the (rear) front lower links are supposed to have a slight curve in them. If you have a significant number of miles on the car and are experiencing such severe wear, then I would look into replacing the rear suspension arms and (rear) front lower links at a minimum. The radius rod, which effectively keeps the rear suspension from toe-ing, could also be bent or the bushings could be worn out, which could cause unnecessary changes in toe while driving.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
jjohns2711
Aug 5, 2015 08:58 AM
brian_z
Jul 22, 2015 09:19 PM
