Clicking noise in front hub?
Old Dec 17, 2010 | 05:13 PM
spinn's Avatar
nightshift, what type of sound do you hear?
Old Dec 17, 2010 | 05:22 PM
NightShift's Avatar
Well its a little hard to type a sound but its sort of a noise that a tire would make but slower its a rotational noise but slower than your driving
Old Jan 3, 2011 | 02:21 PM
spinn's Avatar
Replaced my hub over the weekend. Sourced the part from Rockauto for $120 shipped. Took awhile the first time doing it as there's one bolt to the hub that is kind of a PITA to get to. That and trying to jack a lowered vehicle is also a pain. I say first time because I ended up putting the brake shield on backwards the first time. Second time I took it apart, it went by a lot quicker. Then found out that my rotor hadn't been installed flushed with the hub so I had some grinding after I had put it back together. Required jacking up my car a 3rd time to get the wheel/rotor on properly.
Drove it around and no more 'knocking' sound when making left turns. I do have some rotational rubbing, but it's hopefully just the pads rubbing against the rotors, which hopefully should go away in a few days.
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
rping
Jul 26, 2015 09:53 PM
papo020
Jul 17, 2015 10:30 PM
