Circular grinding mark on front rotors
Old Dec 5, 2010 | 11:53 PM
whoisthis's Avatar
i started noticing this circular marks, very slight grinds, on the both front rotors after SPC A-arm with SHIMS installation. These shims and arms were installed on g35 coupe and it had no problems.
Both the rotors have exact same marks in the same place so i'm going to guess it's from the the shims pushing out the top of the rotors for more positive camber. i do hear some grinding sound only when i apply brake. Never happened before installation.
Both the grinding marks are located where the brake pads contact the rotors.
Does anyone have this problem?
The mark looks like the one in the pic i attached. But it's very slight grind and little wider than the pic but noticeable.
Attached Thumbnails Circular grinding mark on front rotors-kjhlikuhimg_6226.jpg
Old Dec 6, 2010 | 03:08 AM
JBF's Avatar
JBF
how old are your pads?
Old Dec 6, 2010 | 03:15 AM
whoisthis's Avatar
pads n rotors are pretty new.
Old Dec 6, 2010 | 02:50 PM
reverse's Avatar
check the cover over the rotor. i had that issue when i installed my springs. the cover was rubbing the rotor.
Old Dec 6, 2010 | 03:04 PM
whoisthis's Avatar
whats the cover? i checked the inside of the brake caliper but everything looked fine.
If the "cover" is rubbing the rotor then i should hear the griding sound when not applied brake...
tiguy99
Mar 1, 2016 11:42 AM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
miata007
Aug 17, 2015 04:36 PM
jjohns2711
Aug 5, 2015 08:58 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
