cant get endlink off
Old Dec 10, 2010 | 11:49 PM
kennymo's Avatar
everytime i try and take the endlink off(just the lower mount) i cant. i can get the bolt off no problem. but i cant get the endlink itself to come off the lower arm (like if i was trying to remove it so the lca would drop down) i have beat it with a rubber mallet but it wont budge. am i doing something wrong?
Old Dec 10, 2010 | 11:51 PM
tragedycat's Avatar
Trying jacking up the lower control arm to relieve the tension while you are hitting the endlink. Alternatively, you can also try jacking up the opposing side arm to relieve pressure on the sway bar, which can also help it to pop out easier. Hope this helps.
Old Dec 10, 2010 | 11:53 PM
kennymo's Avatar
now im going to feel like an idiot if that works because that is so basic. haha thank you very much
Old Dec 11, 2010 | 12:00 AM
w4kj4k's Avatar
Yeh jacking it up for tension usually works. Let us know how it goes!
Old Dec 11, 2010 | 12:23 AM
ShanesG's Avatar
do you have the entire front on stands? if you only have one side up the sway will push on it and you will never get it out
Old Dec 11, 2010 | 12:37 AM
kennymo's Avatar
yea i only had the one side jacked up. im not in the process of this right now. but i have tried before and will be doing it again so i figured i was ask now
Old Dec 14, 2010 | 11:33 AM
bjquinnIUmed's Avatar
Worst case scenario you just unbolt the front sway bar to completely relieve tension on the endlink...only adds about 20 mins and can save you from a big headache.
jilljann1
Jul 21, 2020 08:12 AM
neight
Steering & Suspension
Aug 7, 2015 02:48 AM
DaveB
Nov 24, 2008 01:31 PM
