Toe setting wrong in manual?
Old Dec 11, 2010 | 11:14 PM
brandon1978's Avatar
I was just comparing front toe settings between the G35 and 350Z and noticed that the mm and inch settings are the same, but the angle is different. I think it is a mistake in the G35 manual.
G35 (from 2006 service manual):
0 mm (0 in) (0.00°)
1 mm (0.04 in) (0.04°)
2 mm (0.08 in) (0.08°)
350Z (from service bulletin NTB04-043a):
0 mm (0 in) (0°)
1 mm (0.04 in) (0.1°)
2 mm (0.08 in) (0.2°) preferred setting
The formula to convert from toe in inches to tow in degrees is:
inv sin (toe in inches/tire diameter in inches)
The math works for the 350Z degrees, but not for the G35. It is easy to see how the numbers could have been screwed up when printing the service manual.
Toe out calculator:
http://www.ground-control-store.com/toe-out.htm
Old Dec 12, 2010 | 11:00 AM
obender66's Avatar
You need to get laid.
Old Dec 12, 2010 | 12:30 PM
eurodre's Avatar
^^+1
Old Dec 17, 2010 | 12:54 PM
adamls2's Avatar
Talking
LOOOOOOOLZZZz!!!!!!!!!!
neight
Accessories
Jun 29, 2020 12:24 AM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
Team STILLEN
Aug 10, 2015 08:17 PM
multimut
Canada
Jul 26, 2015 08:43 PM
jimNC
Jul 25, 2015 05:47 AM
