Are front Camber kits really necessary?
Old Dec 21, 2010 | 03:41 AM
izzueeek's Avatar
I have a question, my car is lowered on s-tech
mine is Front: -2.1 Back:-2.5
is that bad? do i need camber kits too
Old Dec 21, 2010 | 09:30 AM
LightsOut's Avatar
SIETESG
it's well worth it.
Old Dec 21, 2010 | 02:16 PM
caketech's Avatar
i agree with lights out, you will be happier with it.
Old Dec 21, 2010 | 02:50 PM
AARONHL's Avatar
Yupp
Old Dec 21, 2010 | 02:54 PM
The Stimulation's Avatar
You don't need it unless you want it to be OEM spec or your tires are too wide for it to clear the fender. Just set the toe in spec and you'll be fine. I drive daily with -5 up front and camber wear really isn't all that bad and I put on a lot of miles.
Old Dec 21, 2010 | 03:05 PM
LightsOut's Avatar
SIETESG
yes, technically he does not need a camber kit. But Im guessing his wheels are tucked or oem size and will benefit from having a oem spec stance, rather than a slanted stance, that is not aggressive.
Old Feb 15, 2011 | 03:04 PM
xfuz1on's Avatar
I just read about how to SPC shims allow some positive camber as well... Would I need the whole camber kit or just the shims if I'm dropped on z s-techs with low offset wheels?
Old Feb 15, 2011 | 03:46 PM
Tollboothwilley's Avatar
you won't need to install the shims unless you go lower in the future
Old Feb 15, 2011 | 10:48 PM
xfuz1on's Avatar
So if i get a front and rear camber kit, doesn't it come with the shims? Can I just run with the shims without the a-arms? I'm new at this so please bare with me. Am I able to adjust front and rear toe with/without these kit?
Old Feb 15, 2011 | 11:23 PM
tragedycat's Avatar
It's not required but they will pay for themselves after a while from not having to change your front tires as often. Bite the bullet and get it done right the first time, don't cut corners because it always ends up costing you more in the end.
Old Feb 16, 2011 | 12:29 AM
xfuz1on's Avatar
Haha forsure man. So I was doing some research about the SPC front camber kit and there seems to be a lot of issue with these where people's VDC, ABS, SLIP lights all came on after installation. Are there still issues with these? Any recommendations are appreciated
Old Feb 16, 2011 | 12:34 AM
w4kj4k's Avatar
I have SPC front camber arms, and no problems about what you mentioned.
Old Feb 16, 2011 | 12:43 AM
xfuz1on's Avatar
I found it from this thread: https://g35driver.com/forums/brakes-...-spc-poll.html
Old Feb 16, 2011 | 12:44 AM
w4kj4k's Avatar
Im running front 15mm spacers right now, and no light or anything, so i guess im lucky haha
Old Feb 16, 2011 | 12:01 PM
  #30
xfuz1on's Avatar
Do you have the revised arms ?
