Brake pad replacement
Old Dec 22, 2010 | 09:30 PM
Mr. G's Avatar
My brakes are starting to squeal at 45K miles. The local mechanic who has been reliable told me over the phone he would resurface the rotors when replacing the pads and I probably would only need the front axle done.
1. Would you resurface them even if they are not obviously scored?
2. Do you think they might need to be replaced anyway due to wear?
3. What is the best place to get true OEM pads?
Thanks in advance.
Old Dec 22, 2010 | 09:34 PM
thescreensavers's Avatar
Mr.202?
When was the last time you replaced the brakes?
Old Dec 22, 2010 | 10:12 PM
Mr. G's Avatar
On another car! My brakes have been fine for 45000 mi. I don't live in Miami.
Old Dec 22, 2010 | 10:17 PM
5150DS's Avatar
What year car do you have? If it is on 03-04 go with aftermarket pads. If 05-06 stick with stock. I would look at Riverside Infiniti on ebay for stock pads.
Old Dec 22, 2010 | 10:35 PM
Mr. G's Avatar
Thanks, I have an '05, that's why I want to replace with stock. They saved my life once when some kids turned left in front of me when I was going 50 on a two-lane road. I saw the kid's eyes about six feet from mine right before I stopped and he went by. I'm guessing the inside of his car smelled bad afterwards.
What about the rotor questions?
Old Dec 22, 2010 | 10:52 PM
Mustang5L5's Avatar
If you replace pads, you should either resurface or get new rotors. Reason for this is the pad material "beds" into the surface of the new rotor and creates friction material on both surfaces that aids in braking. You don't need to replace rotors...I have frequently "pad-slapped" cars and just replace the pads only.
Squealing brakes doesn't necessarily mean the brakes are done. You really need to pull a wheel and inspect pad thickness. If there is plenty of meat, you can re lubricated the caliper. Noise is caused by vibrations and harmonics.
I bought my oem brake stuff off eBay from Infiniti parts wholesalers. I think I paid about $250 for new rotors and pads up front and did the install myself in no time
Old Dec 22, 2010 | 11:42 PM
Mr. G's Avatar
I think the pads are probably done but I will check. Do the G35 rotors take resurfacing OK? I have heard that bimmer rotors are so thin and the pads wear them down almost as fast as the pads that you often have to replace rotors with pads. Do you measure rotor thickness to see if you can grind them without making them too thin? Thanks for your advice.
Old Dec 23, 2010 | 12:22 AM
5150DS's Avatar
I bought my current rotors from here: http://www.r1concepts.com/infiniti-g35-2005-2wd.htm
Old Dec 23, 2010 | 05:48 AM
toymachine2009's Avatar
Nice link ^^ Also are those rotors direct replacements for our stock rotors?
Old Dec 23, 2010 | 11:13 AM
Blue Dream's Avatar
I drove ttrank's car solo
Yes they are. I bought rotors from the same company and so far have been pleased.
Old Dec 23, 2010 | 02:20 PM
Cool is it easy to replace rotors?
Old Dec 23, 2010 | 02:44 PM
Mr.202?
^ yep but make sure to buy a breaker bar
Old Dec 23, 2010 | 04:41 PM
Just got one lol for when I did my suede headliner..
So I can get any one of those rotors on that site and they should work.. also where can I pickup some OEM replacement pads? Does that site have them?
Old Dec 25, 2010 | 04:53 AM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Yes, the OEM rotors will surface fine. I had all 4 of mine resurfaced about 2 weeks ago when I replaced all my OEM pads to Hawk pads.
Old Dec 25, 2010 | 05:00 AM
Mr.202?
send a Pm to one of the dealers on here. Tim at grubbs and Rick at riverside
I think are the ones. or Get a part number, then you can just google it.
wuppiedog
Aug 7, 2015 11:16 AM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
emorehs
Jul 17, 2015 09:45 AM
