camber adjustment
Old Jan 4, 2011 | 10:25 PM
thebigg35's Avatar
yea just the number so i can start setting my alignment
Old Jan 4, 2011 | 10:27 PM
thebigg35's Avatar
bro y is this guy talking all this smack he think his all smart and ****
eurodre's Avatar
Originally Posted by ChinkyChoy
are tein basics no good?
cut springs are better
-5 up front and -10 in the rear
and don't forget to set your toe to -3.5 all around as well
caster set to +10 and -10
Old Jan 4, 2011 | 10:40 PM
4DGS's Avatar
Basics, BOOOOO
Old Jan 4, 2011 | 10:43 PM
thebigg35's Avatar
hey im trying to upgrade to air suspention i got does basics for hells cheep thats y i pick them up
ChinkyChoy's Avatar
guess you should of went coils
and you arent going to get that gansta camber/caster/toe if you dont have camber kits
Old Jan 4, 2011 | 10:56 PM
thebigg35's Avatar
yea i got basic tien coils and i do have camber kits i have spc rears and ichiba a arms
Old Jan 4, 2011 | 10:58 PM
The Stimulation's Avatar
Ichibas wont get you more than 4 degrees and that's if your slammed....you need to modify those front upper A arms, wouldn't trust that with the Ichibas. And the rear one's, you'll need toe arms, which replaces the spring bucket, which you'll then need true type coilovers, which you have OEM type. You're looking into 2k easy on suspension parts alone.
Old Jan 4, 2011 | 11:04 PM
bluedevils95's Avatar
WWWOOOOOOOOWWWWWWww!!! 2k!!! That's also a lot of work as well. Is that just parts alone or did you go some where to get it installed?
Old Jan 4, 2011 | 11:14 PM
thebigg35's Avatar
wut do u think bout tje spl toe arms?
Old Jan 4, 2011 | 11:21 PM
thebigg35's Avatar
and about the bc br series coilovers?
Old Jan 4, 2011 | 11:23 PM
ChinkyChoy's Avatar
i got the bc coilovers no complaints yet
Old Jan 4, 2011 | 11:28 PM
eurodre's Avatar
stance coilovers if you want to go low
Old Jan 4, 2011 | 11:29 PM
thebigg35's Avatar
the thing with the tien basics is that it didnt lower the rear enough for me how bout with the bc coils?
Old Jan 4, 2011 | 11:34 PM
  #30
eurodre's Avatar
the front can go to the ground the rear has a ring taken off, i can take off the final ring and get maybe 1/4" lower
like I said stance gr+ for the same price and stiffer spring rates
