Handling upgrades !
Old Feb 3, 2011 | 02:04 PM
cmesidewayz's Avatar
True, and i think id have to buy bushings and all that seperately with the stillens...
thanks guys keep the info coming
Old Feb 3, 2011 | 11:29 PM
msommers's Avatar
Originally Posted by cmesidewayz
Ive heard a lot of good things about the stillen sway bars.. any thoughts ?
Also, some sway bars are hollow.. what is the difference between hollow and not besides strength ?
There is a huge sway bar summary that will answer a lot of your questions. Within it is a PDF explaining solid vs. hollow
http://www.whiteline.com.au/docs/bul...%20Swaybar.pdf
Old Feb 8, 2011 | 02:58 PM
jstudrawa's Avatar
Good article, but I am more curious in the torsion rates (is that the right term?) of different manufacturers.
Motordyne doesn't list on their site.
Hotchki's:
Specs:
Front 1 3/8" (35MM) Tubular(Bar Weight 13.5lbs)
4 Position Adjustable
Rear 15/16"(24mm) Tubular(bar weight 5.5lbs)
3 Position Adjustable
Bar Rates:
350Z & 03- 05 G35 Front
Hole 1 = 1525 lbs/in (22% Stiffer than stock)
Hole 2 = 1845 lbs/in (48% Stiffer than stock)
Hole 3 = 2270 lbs/in (82% Stiffer than stock)
Hole 4 = 2855 lbs/in (129% Stiffer than stock)
06 G35 Front
Hole 1 = 1525 lbs/in (5% Softer than stock)
Hole 2 = 1845 lbs/in (15% Stiffer than stock)
Hole 3 = 2270 lbs/in (42% Stiffer than stock)
Hole 4 = 2855 lbs/in (78% Stiffer than stock)
Rear:
Hole 1 = 520 lbs/in (80% Stiffer than stock)
Hole 2 = 655 lbs/in (125% Stiffer than stock)
Hole 3 = 840 lbs/in (185% Stiffer than stock)
Progress:Front Features
-Size: 33mm
-Adjustment Range: 3 holes
-Soft: 777 lbs/in Medium: 926 lbs/in Firm: 1054 lbs/in
-End-links Included: No
Rear Features
-Size: 22mm
-Soft: 310 lbs/in Medium: 425 lbs/in Firm: 550 lbs/in
I'm calling Motordyne to get specs, but how do I know what rate/stiffness I want?
How do the numbers compare in practicality? For example, Progress's firm setting for fronts is less stiff than the softest Hotchki's setting?
I want the handling benefits, but I'm ignorant of sway bars besides the general concept.
Thanks, guys.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
NyCrAzY
Oct 1, 2015 09:19 AM
