Rear shocks or springs worn ???
Old Feb 3, 2011 | 06:35 PM
Tyrone-Biggums's Avatar
In searching for which side that "motorcycle" that has been following me ( rear wheel bearings) I found that when I grabbed the tire to check for bearing play that the left side had some up and down "give" to it and the right side wheel did not.
It is as if the spring wasn't fully seated in the cup (it is) or is too short.... There was not any slop in the joints/links etc - just an inch of up travel with the suspension before it gets firm.
Anyone else ever see this?
Shocks or springs ???
2004 6MT with 97k miles all original suspension.
Old Feb 3, 2011 | 08:56 PM
tyau's Avatar
If your springs are seated properly and there's no play in the bushings or joints, then it is shocks.
Sometimes, a worn or blown shock can still drive normal at ride height for a short period of time before you realize it is in need of replacement. But at full droop, they would have a lot of slack and play.
You are probably not noticing the worn shocks much because of an existing wheel bearing problem that is more noticeable.
Old Feb 3, 2011 | 09:49 PM
Good point - The wheel bearing just started last week and who knows how long the shock has been that way.
Now if I can only pin down which side wheel bearing!
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
miata007
Aug 17, 2015 04:36 PM
si_driver
Aug 11, 2015 07:08 AM
wuppiedog
Aug 7, 2015 11:16 AM
