GF210 with Axis Super Penta 20x9 20x10 245-35-20 275-30-20
G35 coupe
GF210 with Axis Super Penta 20x9 +25 20x10 +25 245-35-20 275-30-20
Will I rub in the front with this setup???
Please someone let me know because I am getting the wheels put on this weekend.
thanks
thanks
im on df210s with 20x8.5 +20 (225/35) and 20x10 +25 (245/35) with 25mm v2 spacers all around so im at -5 and 0 offsets and hardly ever scrub unless i hit a big dip or goin up steep inclines while turning sharp. def no problems with your setup.
edit: :if you arent rolled any, you will still be fine with the drop and wheels. if you feel the need to space them out, then you will have to roll the lips.
Thanks guys for the input I appreciate it.
Citim1ke: what tire size and wheel size are you running on the front?
The only reason Im worried is because I have a 35 series tire on the front, which is a bad move.
