Well I got 350z's pro kit installed on G35 coupe and for some reason the back still looks like stock height. The front got pretty low but the rear didn't I even installed a camber kit and got an aligment and the guy said that it didn't need it came within spec with just the factory adjustment. Any idea why? Im going to do the rear spring mount mod to see if I can get it down a little bit
about two weeks. I noticed the front settled pretty good but the rear still looks the same. I'll post some pics tomorrow
every set of springs is different thats one of the downsides of going that route unless you know someone with the exact same setup as you.. i have tried two different sets of springs - 350z h techs and s techs. i had each set on for less than a month before i decided to go with coilovers. with the springs they never seemed even and the spring rates never work right with the stock struts..
