Help!! Bad rubbing problem!
Old Mar 18, 2011 | 10:11 PM
MTG35guy's Avatar
I just lowered my car on Tanabe Gf-210 and i am rubbing super bad!!
My passenger side is the only side really affected. It looks like it has been hitting the fender and i took out all the screws for the fender liner. Pulled the fender with my hands as much as i could.
It also rubbed a whole in the fender well right where the bumper mounts. Is there a way to fix this issue?
I am running 245/35/20 up front 275/30/20 in the back. Generals.
ANY HELP APPRECIATED!!
Old Mar 18, 2011 | 10:17 PM
CandlestickPark's Avatar
ill Sedan
Pics of your setup?
What are your widths/offsets?
Old Mar 18, 2011 | 10:28 PM
MTG35guy's Avatar
20x9 up front +15 offset
Old Mar 18, 2011 | 10:29 PM
MTG35guy's Avatar
Marcus, you're mr. low i know you know the tricks of the trade.
Old Mar 18, 2011 | 11:16 PM
ill Sedan
A shorter tire up front should stop the rubbing.
Old Mar 18, 2011 | 11:45 PM
MTG35guy's Avatar
you think like a 235/30?
Old Mar 19, 2011 | 12:09 AM
MTG35guy's Avatar
bump
Old Mar 19, 2011 | 02:15 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
If you're sticking with the Generals then a 235/30 will do. Generals run big so your 245/35/20 is like a 255/35/20. You want a 245/30/20 which in Generals sizing is a 235/35/20
Old Mar 19, 2011 | 02:31 AM
Dranom's Avatar
get a heat gun and rubber mallet if you dont know anybody with a fender clamp
take out the screw mounts. Heat it up (needs to be a bit hot to the touch) and flatten the inner lip with the mallet carefully (not too flat or all the way flat its up to you)
like the others said generals are fata$$ tires get small ones
I suggest 225/35 since its cheaper usually. You'll have a bit of stretch and still have that no gap effect
Old Mar 19, 2011 | 11:19 AM
MTG35guy's Avatar
Does anyone know how to resolve the issue with the bumper bracket? i think that is cause a major issue as well.
Old Mar 19, 2011 | 11:35 AM
Dranom's Avatar
Cut it!
Old Mar 19, 2011 | 12:36 PM
eurodre's Avatar
phonebook
Old Mar 21, 2011 | 12:38 PM
CITIM1KE's Avatar
im on df210 my specs are 20x9 +20 20x10 +25 I think its your tire size im running 225/35 and 255/35 generals with zero rubbing
Old Mar 21, 2011 | 01:27 PM
MTG35guy's Avatar
I fixed this issue. Bending the bracket back and shaved down a little of my inner bumper fixed it no problem. I will be running smaller series in the future, I had just bought these before i lowered. Mistake i guess.
Old Mar 21, 2011 | 02:44 PM
JohnnysG's Avatar
How did you remove the bumper bracket?
