Confused about springs... 04 G35 coupe... searched as much as I could..
Sorry if this is a repeat but it should be a quick reply...
I have an 04 G coupe and I want to lower it slightly between .5-1"...
So i was wondering what springs to buy that wont mess up my specs etc.
I looked at the sticky but it doesn't say which springs are the best for my preferences...
So what are the BEST springs that I should buy for what I'm trying to do???
Thanks...
Thanks...
It all depends on what you are wanting out of your ride.
The drop on both the springs you listed are similar, but the Z springs have a higher spring rate.
The "best" spring is what fits your needs the best. Whats best for me isnt the best for the next person.
You will definitely need camber kits with those springs. I just had a set of G S Techs put on my 04 coupe along with Tokico HP's. I also had front and rear SPC camber kits put on. Needless to say I needed both kits to get back to spec. I didn't get the shims put on in front so I have a bit of negative camber (1.5 degrees).
All you picked was a drop length, and if you look at the sticky you can clearly see each spring's drop. You need to take another look at the sticky, s-techs exceed what you previously stated as your desired drop.
laksjd84
Jul 24, 2015 05:12 PM
