wheel bearings - who has replaced?
Old Apr 7, 2011 | 07:47 PM
wanagofaster's Avatar
I have BFGoodrich KDWs and I know they are prone to be loud but like I said I switched them out and it still made the noise
Old Apr 7, 2011 | 10:55 PM
WhosRich's Avatar
I'd say since they only checked the tire for wobble, you should check the bearings themselves and make sure.
Mine didnt have any wobble at all, but the tech checked the bearings and found that they were seized on both fronts. I still get alot of road noise, but now I know that its the tires. So hopefully once I change those out, I'll be good to go. Just dont know what brand are quiet.
Old Apr 8, 2011 | 03:42 PM
How involved is it to replace the wheel bearings. Is it expensive and can i DIY
Old Apr 8, 2011 | 05:20 PM
WhosRich's Avatar
There is a DIY on here for the wheel bearings. The fronts look simple enough to do but the rears are little more intensive.
Old Apr 13, 2011 | 05:51 PM
DaveB's Avatar
Originally Posted by Tollboothwilley
It seems to go away at about 35 mph...but my intake/exhaust aren't exactly quiet either.
$20 it's inner tread feathering. Let me guess, the noise is more prevalent when braking below 40mph. The inner tread block will feel bumpy or scalloped.
Old Apr 13, 2011 | 05:53 PM
DaveB's Avatar
Originally Posted by wanagofaster
Alright here is my problem. The inside noise of my car sounds like a truck with mud tires. I figured it was my tires so I took the wheels and tires off my friends g35 and took it for a test drive. The noise was slightly less but did not go away. I then took it for an alignment for unrelated reasons and they checked the bearings and they said they were fine. I dont know if that is true because they just checked for wobble in the tire. What else could it be tranny? U joint? Rear? im not sure. Thanks for replys
Front tire inner tread block feathering. You've got it. An alignment most likely won't fix it either. There's a problem with the suspension geometry in these cars that cause the issue. It's not the toe setting either.
Old Apr 13, 2011 | 09:12 PM
Tollboothwilley's Avatar
Probably - I had this issue with my previous tires due to the control arm bushings.
However, I hit a pot-hole and its only on one side so i'm pretty sure an alignment will fix it.
Also, I've been lowered for 3 years now and a ton of miles with no issues until my control arm bushings went bad. I don't think its the suspension geometry.
Old Apr 15, 2011 | 04:04 PM
Took it to the shop an they said it is the tires big time not wheel bearings. The fact that the KDWs are agressive tires and they are cupping makes a bad combination. I felt the inside tread on the fronts and it feels like scales between the treads. I tried swaping the tires left to right on the front and back and the noise didnt go away.
Old Apr 15, 2011 | 04:06 PM
The-Dream's Avatar
I need to replace my two front wheel bearings, do you guys know what parts I need exactly?
Old Apr 18, 2011 | 10:19 AM
for your 05 or yiour 08 ?
look at www.rockauto.com and they have good prices. Timken is what I would get.
Old Apr 18, 2011 | 04:38 PM
The-Dream's Avatar
For my 05. How dangerous is it to drive on worn out bearings? I can't change it for another two weeks.
EDIT:
TIMKEN Part # BM500013 Ball Bearing; Rectangle (Mod) Flange Shape
X; Sedan; AWD; Front
Is that the right part?
Old Apr 18, 2011 | 11:31 PM
yeah, that should be the right part as long as you looked it up under 2005 AWD.
you should be ok to drive on it for a little longer but realize that you should swap out both at the same time (i think you were planning that anyways)
Old Apr 19, 2011 | 04:11 PM
The-Dream's Avatar
I was looking under non-AWD 2005 and that's the one that came up. I'm also switching both at the same time yes. Thanks for the help, I really appreciate it. Cheers!
Old May 10, 2011 | 08:10 PM
alex104's Avatar
I have a worn right front hub bearing, do I have to replace both the left and right or can I only replace the right one? thanks
Old May 11, 2011 | 12:35 AM
  #30
AARONHL's Avatar
If you have close to 100K, I would recommend replacing both front bearings. Your rear bearings are going to PEACE OUT soon too. The wheel bearings in our cars are TERRIBLE. I'm pretty sure half of our forum is riding on dangerous bearings.
