wheel bearings - who has replaced?
Old Feb 16, 2012 | 11:47 PM
  #46
AARONHL's Avatar
Rear wheel bearings are always sold separately from the hub and that is my final answer..
Old Feb 27, 2012 | 02:02 PM
  #47
broke_as_ajoke's Avatar
Originally Posted by DaveB
$20 it's inner tread feathering. Let me guess, the noise is more prevalent when braking below 40mph. The inner tread block will feel bumpy or scalloped.
That is what mine is doing.. So I guess I'll replace the tires before I look ingot getting the wheel bearings..
Does anyone know if putting these bearings on difficult?
Old Apr 1, 2012 | 11:04 PM
  #48
bocatrip's Avatar
Mine were screaming at 45,000 miles on my 04 Coupe. I had them replaced under my extended warranty. Wheel bearings years ago lasted 150,000+ miles.
Old Sep 8, 2013 | 12:52 AM
  #49
g35rulz's Avatar
03 g35 sedan here. I noticed the noise would start while I am on the freeway slight right turns. As I am driving taking a slight turn going over 50 mph I would here the right side growling.... verly low at the time. Now a a few months later the noise came back with a vengeance like they say.I could hear it when I am driving straight, when I cut the wheel to the right it got extremely loud. The Mechanic and I went on a test drive and he immediately pointed out it was the bearing from the right.
So he replaced the bearing and we went on a second drive.... damn noise is still there. He decided to install the bearing he removed from right to the driver side.
Third test drive and the noise is finally gone! !
I guess noise does travel.
Old Sep 27, 2013 | 10:32 AM
  #50
Tollboothwilley's Avatar
For all wheel bearings - if you turn right and hear it more its the bearing on the left that is normally the cause of the noise. If you are turning left, and it gets louder change the right side bearing.
Old Sep 27, 2013 | 11:05 AM
  #51
Texasscout's Avatar
Mine were making noise in the back and I confirmed it when I got new tires and it was still there. I tried to change them myself, but I didn't have the tools so I took it to a mechanic I know. He had it done in 2 1/2 hours, charged me 300 bux. BUT, he said "don't EVER bring me another one!"
He looked in the book and it said 5.2 hours to change them, he did it in less than 3 and only charged me appropriately.
I like this guy.
Old Oct 5, 2013 | 11:13 AM
  #52
Jadazio's Avatar
I replaced the whole hub myself in less than an hour. They're bolt on hubs and fairly easy to replace. Hub was $130.
Old Oct 6, 2013 | 10:09 AM
  #53
Texasscout's Avatar
Front or back? If back did you remove axels to get to the hub flange bolts?
Old Oct 7, 2013 | 11:35 AM
  #54
Jadazio's Avatar
It was a front hub, I haven't replaced the rear hubs yet.
Old Oct 7, 2013 | 01:07 PM
  #55
JOKER's Avatar
CLUB MODERATOR
you have to remove axle anyways to get the hub out. I pulled axle to get to the bolts since it had to be removed anyways.
Old Oct 7, 2013 | 02:17 PM
  #56
Texasscout's Avatar
If you look at the service manual, you have to take EVERYTHING apart.
Old Oct 12, 2013 | 10:04 PM
  #57
keithizm's Avatar
Mine sounded like a light scraping noise that resonates louder and louder as time went on.
Old Jul 9, 2016 | 09:46 AM
  #58
_Ghost_G35's Avatar
Mine sound like a plane taking off once I am going over 70mph
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
rping
Jul 26, 2015 09:53 PM
itschuckster
Jul 25, 2015 08:07 AM
