front Toe spec
Old Apr 5, 2011 | 11:08 PM
whoisthis's Avatar
front Toe spec
Hi,
I need help with front toe spec quickly.
I'm replacing my SPC arms with stock arms. If the camber stays around -2.7, i'll stick with stock arms. So my question is, If the camber is around -2.7, what would be the wise number for toe spec for reducing the wear on inner side of tires, AND for DD and autox use? i expect some wear on inner side of tires, but was told that good number in toe will save it.
My car, 350z, is dropped with Stance gr+ by the way.
thanks in advance
Old Apr 5, 2011 | 11:50 PM
the_sedan's Avatar
alot of the stanced guys run close to or at zero on total toe.
Old Apr 5, 2011 | 11:54 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
As close to 0.00 as possible. Spec for the front is 0.00-0.12 IIRC. Rear is 0.00-0.22
When I worked at the alignment shop I would set all G/Z's to 0.05 on either side (0.10 total toe)
Old Apr 6, 2011 | 12:00 AM
whoisthis's Avatar
If it has to be either toe in or out, what's better?
I know a guy who has toe in with more drop than i have. I'm afraid toe in would cause wear on outside.
Old Apr 6, 2011 | 12:03 AM
the_sedan's Avatar
toe out is positive. i wouldnt think toe in would do well on a G. just zero it out. im currently around .12f and .22r but i'll be close to zero next alignment to see if my tires will last a lil longer with my camber settings.
Old Apr 6, 2011 | 12:04 AM
Ideally you want the toe at 0.00
A little toe out (0.05) won't hurt.
Old Apr 6, 2011 | 12:08 AM
whoisthis's Avatar
Thanks guys, i'll try to get em to zero if not, .05 toe IN.
my car is 350z by the way
Old Apr 6, 2011 | 12:10 AM
Don't tell them you want toe in or toe out. Just tell them you want between 0.00-0.05. Toe in on an alignment machine will read -0.01 which you don't want
Old Apr 6, 2011 | 10:20 AM
brandon1978's Avatar
You want it aligned with toe-in because the tires will move out when you get up to speed.
From service bulletin NTB04-043a:
The preferred setting is 2 mm (0.08 in.) [ 0.2º ] ... Once the final adjustment is done, it is very important that there is no "toe-out".
Old Apr 6, 2011 | 11:58 AM
whoisthis's Avatar
accordding Brandon, shouldn't the toe be between 0.00 and negative .05
Old Apr 6, 2011 | 12:11 PM
No, you want the numbers to be positive. Spec is between 0.00 and 0.08 for the front and the rear is 0.00 and 0.22
Old Apr 6, 2011 | 12:16 PM
whoisthis's Avatar
i'm little confused. you want toe IN, but spec between 0.00 and 0.05 ? (isn't positive toe OUT)
Old Apr 6, 2011 | 02:55 PM
the_sedan's Avatar
no, you DO NOT want toeIN. thats negative numbers!
Old Apr 6, 2011 | 03:54 PM
Positive is toe-in.
Manual says spec for G35 front toe is:
0.00in or 0.00° to 0.08in or 0.08°
However, 0.08in does not equal 0.08°, its about 0.2° which is the preferred spec for a 350Z. Next time I get mine aligned, I'm going for 0.2°.
Old Apr 9, 2011 | 02:19 AM
whoisthis's Avatar
Do i still want the toe to be near zero even the camber is around -2?
What would be a good toe number on rear with -1.5 camber?
