Spring Questions
Old Apr 11, 2011 | 03:38 PM
G35sTIMCA's Avatar
Spring Questions
Hi all,
I know this has probably been asked time and time again.
I bought a 2007 G35s 6MT sedan and want to lower it. I am cost conscience otherwise I would go with a nice coilover kit!
I found a great deal on some Tein S-Tech's. However, they are for a 2006 Coupe. Will they physically still fit (Gen I vs. Gen II) and how much more would they lower my car?
Also, I used to be a hardcore Mustang guy (pre-family!). Anytime you lowered one, you needed to change the shocks/struts. Is the same true with the G's. I know it would probably be preferable, but is it necessary right away?
Thanks for your help!
Tim
Old Apr 11, 2011 | 04:12 PM
irishsig's Avatar
The drop for the G35 s techs on a sedan is F-2" / R-1.3"
The 350Z s techs should drop it slightly further, not sure how much though.
The oems struts prob won't match up to well to a drop over 2".
If your looking to save money on the struts I would most likely swap them out for a lightly used set of Tokico HPs or D-Specs.
Here's a link to all the spring/coilover drops.
https://g35driver.com/forums/brakes-...ferrerid=39810
Old Apr 11, 2011 | 05:33 PM
4D05G35's Avatar
Coupe springs will lower the sedan .5" more.
If you are looking at a drop thats more than an inch you are going to want to invest in some front and rear camber arms and Toe bolts for the rear.
Old Apr 11, 2011 | 05:35 PM
G35sTIMCA's Avatar
Thanks for the help! I really didn't want to go more than 1.5 - 1.75" as it is my daily driver. I was thinking eventually I would have to get camber arms, etc too.
Old Apr 11, 2011 | 05:42 PM
G35sTIMCA's Avatar
Physically, are the springs interchangable (GenI & II, 350Z, G35, G37, etc)?
Old Apr 11, 2011 | 05:48 PM
G35sTIMCA's Avatar
I think lastly, there are so many brands of camber arms, which ones should I be looking for?
Old Apr 11, 2011 | 09:30 PM
4D05G35's Avatar
Yes asfar as I know the gen1 and 2 are interchangable.
Look for Ichiba, SPC, SPL, Kinetix, Megan racing, Cusco, etc. Along those lines. Check the vendor area under the market place
Old Apr 12, 2011 | 01:52 PM
G35sTIMCA's Avatar
This newbie really appreciates the help!
Old Apr 12, 2011 | 06:51 PM
4D05G35's Avatar
There is a wealth of knowledge on this site. It is by far the best automotive forum that I've belonged to.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
joel extreme
SOCAL Meetings & Events
Aug 7, 2015 03:09 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
