Wheels tire camberkit coilovers??? Im lost...
Old Apr 15, 2011 | 03:00 PM
andyrooroo89's Avatar
Alright, Im admitting it, im a noob. Im looking at either TSW Cadwell Gunmetals. I am going to go for the staggered fit but im unsure whether to go with 18s or 19s or what offset i need. Im wanting them just barely tucked.The stagger is 8 in front and 9.5 in the rear. Also, im wanting to drop it just enough to close the gap between tire and wheel well. But i absolutely DO NOT want the chance of it rubbing going around corners. My basic question is what coilovers should i go with and will i need a camber kit? Thanks a ton in advance.
Old Apr 15, 2011 | 07:41 PM
4D05G35's Avatar
Depends on if this is going on a coupe or sedan.
Old Apr 15, 2011 | 07:53 PM
this an 04 coupe. brembo brakes as well
Old Apr 16, 2011 | 01:19 AM
4D05G35's Avatar
Most of the TSW wheels have a weak offset when it comes to a coupe.
If you are looking for an 8/9.5 stagger you will want an offset around 10 to clear with no rubbing issues (lower offset will look better and be flusher).
If you are looking to tuck the wheels then yes you will need coilovers.
F/R camber kits will help tire longevity(save from some camber wear). The bare minimum you will want is aftermarket toe bolts for the rear.
The rest is personal preference.
Old Apr 16, 2011 | 01:29 AM
When i say tucked i mean i dont want them perfectly flush. I want them to set inside the wheel well... not actually up in the wheel well though.
jsimonk
Dec 22, 2023 03:49 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
JaeXL
Aug 4, 2015 07:43 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
