Control Arm Bushings for X?
Old Apr 15, 2011 | 03:04 PM
G35xChicago's Avatar
So my front lower control arm bushings are bad, I want to replace the crappy stock ones with the nice polyurethane ones from Whiteline.
Does anyone know if these will fit the X? Im pretty sure the control arm itself on the X is different, but infiniti does not break these parts down to the bushings.
Do you think they would use the same bushings in the front control arm?
Thanks!
Old Apr 15, 2011 | 04:10 PM
tark's Avatar
Thanks!
I've got the same problem but i was thinking about changing all of the control arm.
Old Apr 15, 2011 | 08:24 PM
Anyone?
Old Apr 18, 2011 | 12:20 AM
bump
Old Apr 27, 2011 | 02:20 PM
Someone help us out here. Turtle, im waiting for your response
Old Apr 27, 2011 | 02:31 PM
Old Apr 27, 2011 | 02:40 PM
OKStateG35's Avatar
This question comes up quite a bit and nobody has ever answered it. From what I can tell, the only way to find out is to buy the bushings and see if they fit.
I'm considering ordering an entire front & rear kit from Energy Suspension. My only concern is that apparently they are noisy.
Old May 5, 2011 | 11:32 PM
bump for possible answers
Old May 6, 2011 | 12:07 AM
vinco's Avatar
Nope, the ES kit is not noisy at all - just lube it up good as you install the bushings! I love mine on my coupe!
As far as fitment on the X, it's my understanding that there's no difference, since the arms are all interchangeable. However, I will not swear to that or offer any guarantee as to its accuracy, since I don't have an X to compare with.
Old May 6, 2011 | 08:22 AM
OKStateG35's Avatar
Good to know on the noise. Did you install yourself or take it to a shop?
Old May 6, 2011 | 10:15 AM
vinco's Avatar
Did it myself. There's a writeup a few threads down.
Old May 7, 2011 | 05:06 PM
im pretty sure the arms on the X are different, esp. because there is a different part number from infiniti. But youd think theyd use the same bushings, why make different bushings?
Old May 8, 2011 | 01:46 PM
vinco's Avatar
The X uses steel radius arms, where the others use aluminum. They are geometrically the same, though. I'm pretty sure they are functionally interchangeable.
Freeman186
Sep 6, 2023 10:07 AM
jilljann1
Jul 21, 2020 08:12 AM
mattdg35
Sep 14, 2015 11:28 AM
TheBay
Sep 3, 2015 03:27 PM
