Is there a difference between 350z and g35 brake rotors and pads
Old Apr 20, 2011 | 12:57 AM
jmonsale's Avatar
Specifically the difference between 03/04 350z oem rotor size and pads compared to the 03/04 g35 oem rotor and pads? Reason I ask is a friend needs rotors and pads for his 350Z and I have a barely used set from my 04 g35
Old Apr 21, 2011 | 07:26 AM
obex26's Avatar
During those years the only difference I have observed is pending on Brembo and Non - Brembo applications. I want to say 07-08 is the first change to the brakes and other suspension components that actually come with larger rotors, calipers and different spindles.
Correct me if I am wrong.
Old Apr 21, 2011 | 07:59 AM
PAIXAO's Avatar
I have 04 350z pads and rotors on my 04 sedan.
Old Apr 21, 2011 | 07:37 PM
ryanm8's Avatar
06 is when Nissan upgraded the whole brake system on the 350Z. I believe the 06 350Z brakes are the same as the 05+ G35 brakes... They're 2 piston fronts with a larger brake pad.
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
kinetek
Aug 3, 2015 04:25 PM
RedBaronK
Jul 27, 2015 03:19 PM
laksjd84
Jul 24, 2015 05:12 PM
